jean12
Advanced Member level 2
Hello there ,I am design a pressure sensor alarm which uses MPX2100GP interfaced to PIC16F877A;the MPX2100GP is interfaced to an amplifier with TL084 which amplifiers the 1mv generated at 1KPa for getting a good analyzable value;because that sensor MPX2100GP its output is a voltage of some 2.815V and when the pressure is applied on it it changes a little bit, with ccs c compiler I am reading 20 successive numbers in 1minutes and then find the largest and lowest and the difference of the two numbers gives the pressure so that pressure measured can be used to activate the buzzer for example for some limit.
Can you please help me to find the largest and lowest numbers in those 20 digits?
Thanks.
Thanks.
