Khelz
Newbie level 6
- Joined
- Mar 13, 2013
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,401
Hi Guys,
Here is the situation:
I am measuring the current flowing in a high voltage circuit (attached). Basically I am measuring the current through the shunt resistor which outputs a voltage proportional to the current
then I amplify the voltage difference with an in-amp and I acquire that on a scope. The problem is that the HV supply carries a large 60 Hz component noise and this gives a poor signal to noise ratio. Now the thing is that I cannot low pass or high pass filter the whole thing because the signal of interest has 2 components occurring at frequencies lower AND higher than 60 Hz.
So I thought that a solution would be to filter the High dc voltage BEFORE it reaches the shunt resistor, which could get rid of the 60 Hz component without filtering the signal at the same time. Since the current pulses come from the reactions at the load (chemical reactions) I thought that may make sense, but I am not sure if it possible to filter the voltage before it reaches the shunt resistor without affecting the whole circuit response.
What do you guys think?
Thanks a lot. View attachment Electric Circuit for support.pdf
Khelz
Khelz
