mnasser431998
Newbie
Hello,
I'm currently working on a project with 180nm smic. The lef files are quite old from about 2003. I converted them into milkyway files with the milkyway.
Everything went good until I came into the step of adding the filler cells, the icc complains that the cells I'm adding are not filler cells. I'm sure they are as I read the datasheet.
can you suggest a solution for this problem.
Thanks in advance,
mnasser
Thanks in advance,
mnasser
