File size limit exceeds error in Fedora Linux
mparvathi
file size limit in linux
Hello All,
am running a video application in Linux platform.WHile execution i am getting an error like "File size limit exceeds" , I refered web sites. Found ,
"Your system administrator must have imposed limitation on your account for file size creation" from https://www.cyberciti.biz/faq/file-size-limit-exceeded-error-under-linux-and-solution/
So i set file size unlimited using "ulimit -a "...
Still the problem remains. I am in a very tight schedule. Any suggestion is highly appreciated.
regards,
M Parvathi
idhaya
Newbie level 1
fedora 8 limit file size
did u get the solution for ur ques?
If so post tht in this.
Otherwise try the following
" add the flag -D_FILE_OFFSET_BITS=64 while compiling "
