file of the schematic (Orcad) for the rabbit board needed
angheus
Newbie level 6
Newbie level 6
Rabbit
Hello,
I need the file of the schematic (Orcad) for the rabbit board.
Please help me
Here it is.
Hope it helps.
Rabbit schematic
You have all schematics in the Dynamic C folder, if you use this. I can give you the schematics in pdf format. If you pretend construct a rabbit board, I say you that the RCM2200 have low cost compared with any design multilayer Rabbit based. Its cost U$S 45. Regards.
If you need help, let me know.
I made some boards for Rabbit.
Hi ljmnunes and others,
Is it possible for you to share your designed PCB here? I am working with the RCM2200 module. I need a PCB which I can plug the RCM2200 module and do some experiment (e.g. flashing LED...etc.) .
Hi, Dspnut.
I can't post our PCB file because ythe PCB is made for us by another company, so I haven't its file. We make only the schematics.
But what is your problem? If you describe it, may be I can help...
[]s
ljmnunes
Rabbit PCB
I have designed a board bassed in RCM 2200. Here I have attached a pcb library in Protel format. This include a footprint called RABBIT_HEADER. Regards.
Hi all,
What I am working on is a system which connect a barcode reader and a number peripheral devices with the RCM2200. The RCM2200 is connected to the LAN. I think you get the idea now.. :) I will try your PCB joebazoka. I cann't say the T word here since it is prohibited.. So..I appreciate your help... :)
Dear firends what is your opinion on Rabbit chips?
I think they are great chips... lots of posibilities with them. Small learning time.
