JohnFid
Junior Member level 3
- Joined
- Oct 22, 2012
- Messages
- 29
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,283
- Location
- Greece
- Activity points
- 1,474
Hello,
I implemented on HFSS the structure below and I want to monitor fields between patch and ground in various frequencies, in a range over a band gap zone. I managed to produce the bandgap zone by using HFSS's eigenmode solver. To monitor fields do I have to change the solution type? If yes, what type of port must I use? Plane wave or floquet port? Moreover, what about the boundaries and the airbox that I should use (etc height)?
Thank you.
Thank you.
