field distribution problem in HFSS
walaa3d
Member level 2
hi, in the field distribution fig : what is the meaning of the values showing in the key of the figure (1.1397e+006)
That is just the max amplitude of the electric field u can get from ur structure using the default power excitation level of 1W. the power level at the input port can be controlled if u right click on Field Overlays-->edit sources and u can assign the desired phase and amplitude to the input power. If u change them, ur field reports will change as well.
Hope this helps.
I.
    walaa3d
thanks very much, but what imean is how come this high value of E-field (1.1397e+006 V/m)
i think it is unlogic!
