fiber optic for cctv connection
danesh
Full Member level 3
cctv connection with optical fiber
hi there,
i would like to know is there any connection on close circuit tv conected using fiber optic ,is it cost effective compared to conection using wires?
do any one have info on ftth?
thank you
regards
danesh
hi danesh
Fiber optic is expensive compared to coaxial wire for example. In what country you are in?
In USA a cheap coaxial (they buy it cheap) cable holds cable TV channels signals to about let say: 20 different apartments in a small building. I never believe they all see the same tv channel forget about pay-per-view and other perks in cable-tv.
If they do not have picture-to-picture TV, as the matter of fact they do share the same wire, that would mean that cheap coaxial cable I am talking is capable for 20 tv signals with their appropriate coding/compression schemes/modulation etc.
a) How far and b) how many signals you will carry for this fiber or coaxial cable in this CCTV network?
If you have for this CCTV network for a large distance (which I doubt it in cctv) or about 50 signals then go for fiber optic. If is it 10-20 signals then a cheap coaxial cable will do the job fine also.
I hope his helps.
This issue is quite complex.
In small intallations almost 100% is co-axial cable. This is normal AM-modulated video signal and with most of cables (RG-6, RG-58, RG-59...) yu can put as many TV channels (VHF...UHF) as you want...normal TV or VCR can be used as receiver.
Significant number of industrial installation use optical fiber (single core or multi-core) to transmitt video signals (with data or sound) over long distancies or in noisy environment. In this case the video signal is FM-modulated and you need transmitter and receiver pair to transmit video. This is more expensive but pays-off as the video quality is superior, regardless of distance or electromagnetical interfirence.
In most cases cost determines which type of transmission is used and in most cases the cable is still more cost effective.
Thanx Dear IanP for the important info about Cabling types.
Regards.
