FFT on dsPIC33FJ64MC802
The Microchip C30 compiler comes with a dsp library.
If you look in 'dsp.h' you will find a lot of fft function prototypes that you might be able to use?
I have done the fft on this processor on CCS compiler.
you can use the code from here
https://www.edaboard.com/threads/195898/
for any help , you can ask me .
whereas if you want to do it on the C30 compiler then it is also a good alternative.
Hello!
dear all
I want to impliment 256 points fft on dsPIC33FH64MC802.
I have Microstick Module.
Can anyone help ?
I don't think it's the right way to start.
- Try to find some general purpose fft code
- Compile it on your device
- Input a known signal, for instance a sine wave with an
integer number of periods in your interval so that the result should be
2 peaks and 0s elsewhere.
- If there are errors, then you can come back and describe accurately what happens
so that the other users can help you.
Dora.
