FFT matlab: wrong 0Hz frequency
roujhan
Newbie level 2
Hello
I want to use fft in MATLAB to analize some exprimental data saved as an excell file attached here as a doc file.
my code:
A=xlsread('Book.xls'); G=A'; x=G(2, : );
N=length(x);
F=[-N/2:N/2-1]/N;
X = abs(fft(x-mean(x),N))
X = fftshift(X);
plot(F,X)
But it plots a graph with a large 0Hz wrong component, my true frequency is about 395Hz and it is not shown in the plotted graph.
Please tell me what is wrong.
Any help would be appreciated.
JoannesPaulus
Advanced Member level 3
USA
I do not see the large 0Hz component... did you zoom in? There are two tones (-fo and fo) in my plot. You also need to set the frequency axis according to your sampling frequency and length of the capture, not just F=[-N/2:N/2-1]/N;
fcfusion
Full Member level 4
The 0 Hz component shows probably because your signal has an average value different of zero.
roujhan
Newbie level 2
Hi, Thanks for your answers
But I subtract the mean value.
albbg
Italy
I tryed to analyze your data. You didn't specify the sampling time, however if the time data are in seconds I assume it is 4 us.
What I can see in the FFT is a large peak at roughly 500 Hz and other low amplitude peaks. No DC is present. There is no need to subctrat the mean value since it is already 0 (very close to).
Did you zoom the FFT window in a region close to the DC ? Possibly you saw the two peaks (-500 Hz, 500 Hz) very close one each other confusing them for a single peak.
I used this code (actually is Scilab code but it is very similar to Matlab):
Res = 50; // refers the power to 50 ohms resistors
f=(-(N/2-1):(N/2))/(N*tsamp); // N number of samples, tsamp sampling time
val = abs(fft(x));
val = fftshift(val);
val = val./length(f);
val = val./sqrt(2); // recover the amplitude from peak to RMS
PmW = 1000*val.^2/Res; // power in mW
PdBm = 10*log10(PmW); // power in dBm
you can plot both PmW or PdBm versus f. Plotting dBm you will see more in detail the floor and the low amplitude peaks.
