fft ip core in virtex4
miryama
Newbie level 5
shiraz,iran
Hi
i want to know how many fft core can use in virtex4(512 point,scale or unscale and in radix4) ?
it means for all sources how many cores we can use?
Who can help?
thx.:idea:
syedshan
Advanced Member level 1
Jeonju, South Korea
Dear Miryama,
Of course it depends on your design. How much bigger design are you using (including and fft)...
The best way to know is to make one...U see as a proverb says, "when u do you understand" ...:)
Then synthesize if you are using Altera or xilinx fpga, then Quartus and ISE will tell you how many resources have you used up. If exceeded even then you will get to know
and hence you get to know your limit... (ofcourse others also might do but no experience of them :) )
So Do it your self and you'll get your answer... Hope this answer works :)
Cheers
Shan
miryama
Newbie level 5
shiraz,iran
thx shan
i I know this method but when i use several fft in design and synthesize it show me 350 warning and don't show resources that use.
of course this program is only a test.
again thankful:|
syedshan
Jeonju, South Korea
Dear
Well I am not an expert, just a learner but if you can post some of the repeated warnings. May be I or someone else can help u out.
May be warnings are becasue of some different reason. Well make an account on www.forums.xilinx.com and ask there as well. and If found answer do share here...
miryama
Newbie level 5
shiraz,iran
Dear syedshan
i can solve this problem,
ise can't generate several core Simultaneously but if in each step add 1 or 2 fft's to design show resources Surely .
thanks Shan.
i can't make an account on www.forums.xilinx.com.;-)
