snoop835
- Joined
- Feb 7, 2005
- Messages
- 102
- Helped
- 6
- Reputation
- 12
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Penang, Malaysia
- Activity points
- 1,371
Hi everyone,
I am a beginner in Analog IC Design. I want to run FFT analysis using HSpice to determine the dynamic Range of 1st Order Delta Sigma modulator. The syntax I used is as followed.
.fft v(output) np=4096 start=0m stop=1m freq=1k window=rect
This analysis is run in parallel with transient analysis and the output for FFT analysis is a graph X-axis(Frequency) versus y-axis(magnitude in dB).
The question is, how do I measure the Spurious Free Dynamic Range from the output plot?
I know that from definition, Spurious Free Dynamic Range is a difference between highest peak of fundamental frequency(1kHz in my example) and the highest peak of second harmonics. From the FFT output, I can determine the highest peak for fundamental frequency but how do I determine the highest peak for second harmonic? Im a bit confused at this part!
Anyone can help? Is there any good tutorial for this measurement?
regards,
leyman
regards,
leyman
