[SOLVED] FFT 7.1 core outputs are the same
panos_papajohn
Member level 2
Hi ,
I want to use the FFT 7.1 logic core in Spartan3E. I did a 16QAM mapper and I want to connect it to the FFT in order to make an OFDM modulator. The problem is that the outputs of the FFT (real and imaginary) are both the same when the conversion is done. What am I missing? here is the code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity connect is
port(Data : in std_logic_vector(3 downto 0);
			clock : in std_logic;
			Re_part : out std_logic_vector(7 downto 0);
			I_part :out std_logic_vector (7 downto 0);
			reset : in std_logic);
end connect;
architecture Behavioral of connect is
component fft is
port (
	clk: in std_logic;
	sclr: in std_logic;
	start: in std_logic;
	xn_re: in std_logic_vector(7 downto 0);
	xn_im: in std_logic_vector(7 downto 0);
	fwd_inv: in std_logic;
	fwd_inv_we: in std_logic;
	scale_sch: in std_logic_vector(7 downto 0);
	scale_sch_we: in std_logic;
	rfd: out std_logic;
	xn_index: out std_logic_vector(3 downto 0);
	busy: out std_logic;
	edone: out std_logic;
	dv: out std_logic;
	xk_index: out std_logic_vector(3 downto 0);
	xk_re: out std_logic_vector(7 downto 0);
	xk_im: out std_logic_vector(7 downto 0));
end component;
component QAM is
port ( data_in : in  STD_LOGIC_VECTOR (3 downto 0);
           im_part : out  STD_LOGIC_VECTOR (7 downto 0);
           real_part : out  STD_LOGIC_VECTOR (7 downto 0);
           clk : in  STD_LOGIC;
			  start_out : out std_logic);
end component;
signal str :std_logic;
signal imag, re : std_logic_vector(7 downto 0);
signal const :std_logic;
signal clear :std_logic;
begin
stage1 : QAM
port map(Data, imag, re, clock, str);
stage2 : fft
port map( clk=> clock, sclr=> clear, start=>str, xn_re=>re ,xn_im=>imag,
 fwd_inv=>'1', fwd_inv_we=>'1' ,scale_sch=>"00000000",scale_sch_we=>'1',xk_re=>Re_part,xk_im=>I_part);
process(clock,clear,reset)
begin
	if(reset='1') then
	clear<='1';
	end if;
end process;
end Behavioral;
Thanks in advance
