T
treez
Hello,
We are using this connector for 12 Amps of current.
The hole into which the ferrule should be inserted is 3mm in diameter.
Can you confirm that this connector is only for use with ferrules of 2.8mm in diameter (otherwise there will be improper connection)?
Riacon 360272 connector…
https://www.farnell.com/datasheets/91590.pdf
..here it is in Farnell..
Farnell 1688167
https://www.farnell.com/datasheets/1513085.pdf
Farnell 1688167
