Ferrite Transformer Calculation
himmler
Newbie level 6
ferrite transformer calculation
How do i caclculate the area needed for a ferrite transformer , knowing the power needed ? Is there a formula ?
stefano.delfiore
Member level 2
Italy
ferrite core transformer calculation
the design of a ferrite transformer is a trade-off, there isn't a direct relation between core cross section area and output power. A good starting point could be the application notes that you can find at this link **broken link removed**
These application note are written by Colonel Wm. T. McLyman, you can buy his books at http://www.ejbloom.com/
stefano
ghaly
Newbie level 6
Hi
you will find more than the information you need in any design book of smps I suggest switch mode power supply a book written by Heith
Regards
himmler
Newbie level 6
ferrite transformer calculator
I have 2 ferrites with AL = 8600 each.
If i put them together to double the Ae (efective aria) ... what happend with AL ? It is doubled too ?
nec3
Junior Member level 3
ferrite core al calculator
It will stay same .. (a little late ? )
xu.hob
Newbie level 5
we can design the transformers and inductrors.
goldsmith
Advanced Member level 5
Tehran - IRAN
Re: ferrite transformer calculation
Hi. i find a good methode for calculate inductors and transformers. i 'll send my methode for you as soon as possible.
Best wishes
Ali.R.Alemi
