FEKO Problem: Segment Numbers!
borjijiji
Junior Member level 3
feko troubleshoot
In FEKO segment numbers (around a loop, for example) are random and When I use 2D plot of current segments vs. segment numbers I get nothing! (instead of a sine or etc.)
Anyway to sort number?
e_m_c
Full Member level 3
Land
probleme feko
You can export wires in NASTRAN format, update it manually in ASCII text-editor or mesh-editor like ReMesh or Hypermesh or FEMAP. If you could upload file - I can try if it is not very large.
borjijiji
Here is the file for a very simple simulation
e_m_c
Full Member level 3
Land
Everything is OK with model - I have it just opened and calculated - result attached - no problem with segment numbering.
mvr
Member level 1
If the number of segments are too many you could manually renumber them by using "select mesh element" (one of the blue icons near the top middle in CADFEKO)
Then save the model. Just remember that if you remesh the old mesh that you changed manually will be overwritten.
Else you could create the wire loop in EDITFEKO which will give sequential numbering from the beginning.
