Hello everyone,
I'm a bit stumped when using FEKO. I'd like to obtain the input impedance of an antenna, which I estimate to be approximatley 200-300 ohms (folded dipole). In POSTFEKO, there is an option to "subtract loading" above the reference impedance. As far as I can tell, this needs to be checked in order to obtain the correct input impedance. Am I correct?
I somewhat checked my answer by looking at S11. To see how well the antenna matches to a 200 ohm transmission line (S11 magnitude), I've been checking the box "subtract loading", and a reference impedance of 200 ohms. This result matches the graph obtained when hitting the "s-parameters" button, assuming a reference impedance Z0 of 200 ohms in CADFEKO.
Any info would be great. Thanks!
