mtwieg
Advanced Member level 5
I'm going to have to feed a DC supply (48V at 40A max) through a filter panel into a shielded laboratory (working frequency in the 100-150MHz range), and am looking for a robust solution that doesn't compromise the shielding. Panel mount feedthrough capacitors are the basic option, but I am worried about their physical robustness. I've used the smaller ones with pins in the past and found that they don't tolerate stress too much before failing. There are also larger ones with stud terminals, but their datasheets don't say much about what they can handle. I would probably have to mount some sort of strain relief onto the panels, which would take up a lot of space.
Are there any off the shelf solutions for feeding high power through a shield? Using an N type coax feedthrough also occurred to me, but we don't have tooling for that, and don't want to drop a huge amount of money on such a thing.
