Players
Junior Member level 1
I have some problems in FDTD to get help.First thank you for your reading.
1. Zin(w)=V(w)/I(w), how to locate the contour of H for I(t)? Take a dipole as an example. The contour should be around the feed gap or around the arm?
2. When we calculate a strip dipole (thickness=0), a contour for I(t) is also needed.Should I include the H components along the direction of thickness?
3.If PML is used,should a certain distance between the antenna and the PML be left as that of Mur ABC?
Thank you for your answers!
