FATAL_ERROR:Xst:Portability/export/Port_Main.h:143:1.17
arunbv123
module find(clk,reset,V,a,p,
parameter X=1;
parameter NUM=5;
parameter a1=2;//constants
parameter a2=2;
parameter b1=1;
parameter b2=1;
input clk,reset;
inout [0:NUM-1]V;
input [0:NUM-1]a;
input [0:NUM-1]p;
reg [0:NUM-1]ve;//temporary value
reg ab1,ab2;
assign V=vel;/*including this statement will introduce the error : FATAL_ERROR:Xst:portability/export/Port_Main.h:143:1.17 - This application has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at **broken link removed**
initial
begin
ab1=a1*b1;
ab2=a2*b2;
end
always @ (posedge clk or negedge reset)
begin
if (reset == 1'b0)
begin
end
else
begin
ve[0]<= x*ve[0] + ab1*(p[0]-a[0]);
ve[1]<= x*ve[1] + ab1*(p[1]-a[1]);
ve[2]<= x*ve[2] + ab1*(p[2]-a[2]);
ve[3]<= x*ve[3] + ab1*(p[3]-a[3]);
ve[4]<= x*ve[4] + ab1*(p[4]-a[4]);
end
end
endmodule
I given code above. ' V ' variable it is a inout port because the previous value is given as input and the new value is calculated and then stored in the same variable. As the inout port should be a wire. the calculation is done in behavioral block with a temporary register ' ve '. but including the assign statement to update V introduces the error mentioned.
FATAL_ERROR:Xst:portability/export/Port_Main.h:143:1.17 - This application has discovered an exceptional condition from which it cannot recover. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at Xilinx: Product Support & Documentation.
