FATAL ERROR while simulation in xillinx
pranky pranky
Newbie level 1
I am designing 70 bit carry look ahead adder in xillinx using ISIM SIMULATOR 14.5 on spartan 6 with device xc6slx45 and package csg324 .when i simulated it ,i got a fatal error same as below:-
FATAL_ERROR:Simulator:Fuse.cpp:217:1.95 - Failed to compile one of the generated C code. Please recompile with -mt off -v 1 switch to identify which design unit failed. Process will terminate.
then i tried to resolve the problem by adding -mt off and -v 1 switch.but the problem continued and it shows low memory problem.
what might be the reason.plz help.
Does not resolve the problem, is used to indicate where your problem resides
Doesn't this answer the question? Get more memory or run it on a machine with more memory.
