Fatal Error inQUARTUSII?
zarakhan
Member level 2
what is this error? What can I do to work around this problem?
*** Fatal Error: Access Violation at 0X00FACB10
Module: quartus_map.exe
Stack Trace:
0x5cb10: HDB_ACTION_PT_INSTANCE::get_m_rooted_at (DB_HDB)
End-trace
In addtion to the suggestions made in your previous thread https://www.edaboard.com/threads/280127/#post1199849
There's a certain risk that the error is brought up by an invalid design that isn't expected by Quartus. In this case removing design parts incrementally can usually help to identify the problematical design construct.
Hi.I solved this Fatal Error,finally.I didn't have delete old project's signal names from waveform file.:oops:
