Register Log in
Fast Sweep Setup errors
Perhaps__
Newbie
When I simulate my patch antenna design I get a error like "fast sweep setup process hf3d poor convergence in computing port dispersion"
How can i get correct results for my simulation? I want to design an array antenna(1x4) for 5G as my graduate project. You can give me also recommendations. Thanks..
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
fast sweep
poor convergence
This sounds like you're doing a frequency sweep, correct?
Is it possible you're changing frequencies so fast that the simulation has trouble converging on a stable solution for each timeframe? Which could mean you should slow the sweep.
Perhaps__
Newbie
I understand that I should increase step size for frequency sweep. I will try on it, thank you. It is uncertain that some values of a parameter give me good results without error but some of them also give errors like w70 = 0.1mm is well about convergence but 0.12mm is not.
vfone
Advanced Member level 5
Using the provided file I am not getting any error...
vfone
I don't get any converge error messages.
Toggle Sidebar
