Elec-engineer
Newbie level 2
- Joined
- Jun 8, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 18
Attached is a part of the schematics of the board. DO_TEC_HS and DO_TEC_LS are coming from microcontroller at level 3.3V. My question is when the microcontroller gives a 3.3V,8KHz signal to DO_TEC_HS pins, can the bootstrap circuit handle the speed it? The Vin to this circuit can be from 16v to 60V.
If the DO_TEC-HS is 3.3V (continuously on), the outputs Q8 and Q11 will be on, but my main concern is if the input is 3.3V, 8KHz, I have seen my board works fine in one direction but the other direction output is not right.
Thank you in advance!
