Thanks you SO MUCH !!!!! I got it working on my Serial Port on Win7-64.... (Installed and also running in Win 98 mode)
1 More small question If you would happen to know..
In the past Ive programmed (on this JDM Generic)..(serial)(with ICPROG) a Pic12F629... First I had to READ the chip INTO the ICPROG and goto the bottom and look for the 4 DIGIT Code for the OSCillator, Write it down, Load my HEX, Edit that OSC Back into the program and then WRITE IT,,
Now Im using a 12F683, And WinPic800 (3.64) and Serial.
When I goto do a 12F683 do I NEED to READ it in 1st to get a OSCillator # first ?
I can also post the HEX (or email) it to you if you need to look at it first to see
And Thanks again for the REPLY I know the Win98 mode may have been a simple trick but I spent a HOUR last night and still didnt figure it out ;(
-jeff
