I'm using 14,1 version because at my university we are using a FPGA that is only compatible with ISE 14,1
Sorry, but the device list is identical between the two ISE versions:
Page 15:
ISE 14.1
Page 8:
ISE14.7
On the previous page the supported OS(s) for both verisons are:
Microsoft Windows Support
• Windows XP Professional (32-bit and 64-bit), English/Japanese
• Windows 7 Professional (32-bit and 64-bit), English/Japanese
• Windows Server 2008 (64-bit)
Linux Support
• Red Hat Enterprise Workstation 5 (32-bit and 64-bit)
• Red Hat Enterprise Workstation 6 (32-bit and 64-bit)
• SUSE Linux Enterprise 11 (32-bit and 64-bit)
So use ISE 14.7 unless your device compatibility problem is due to licensed vs webpack tool versions, then your out of luck unless your university upgrades their license.
Also as Tricky suggested try a SUSE or Red Hat Linux VM on your Win10 machine that should allow it to run on the correct supported OS.
You might also want to provide the exact messages (log/transcript) of the compilation process, might be something else that is causing your problem that is way further up in the compilation.
