Precision99
Member level 2
I chanced upon an earlier thread entitled Gyroscopic Precession. In the discussion, someone proposed attaching a generator to the axis of precession rotation. If a load is connected to the generator, then it will create an opposing torque drag on the precession rotation. Work has thus been done by the generator, and energy has moved from the gyroscope, to the generator. One poster, think it was c_mitra, stated that this energy must come from the rotation of the spinning gyrospcope wheel, which as a consequence would slow down.
I disagree. The gyroscope rotor is supported by bearings. For the purpose of this discussion these bearings are assumed frictionless. By definition of what a bearing is and what a bearing does, there can be no torque transmitted from the shaft to the rotor, and as nothing else is in physical contact with the rotor, there can be no torque imparted to the rotor, period, and thus the proposition that braking the precession rotation will cause the gyro rotor to slow down (angular deceleration) must also be wrong.
Anyone care to comment on this? What exactly will happen if you oppose the precession rotation, and where will any energy thus extracted come from?
