Chullaa
hello!
I have a pwm circuit that can be used to control speed of a motor. The duty cycle is set by variable resistor R1 manually. I want to control the duty cycle by using microcontroller (PIC16F877A) by either digital or analog ports. Is there any suggestion. Can i replace POT-meter with a BJT transistor in unity amplifying mode by changing its resistance.
oh another! i don't want to use PIC's build in PWM.
thanks
regards
Chulla
thanks
regards
Chulla
