External Library "generic.sdb" not found
libing
when i transport edif from synopsys to cadence , i met the problem that is "External Library 'generic.sdb not found' " .HOw can deal with it?
who can help me? Thank you very much !
u take netlist as verilog or vhdl format not sdb format
then u will try it will work
thank you very much
i can use dc synthesize the project and produce synthesized netlist in verilog format ,but after I imported the netlist into cadence and use nc-verilog to perform post-simulation,i met software error ,maybe caused by cadence software bug .i can not deal with it .
so i want generate edif file and import it .
i tried using CSI to call DC to perform synthesis and then import design .but i found it can not generate edif file at all.maybe it caused by mismatch of symbol scales.
