External interrupt PIC18F4520
r_guna_sekar
Newbie level 6
Chennai
hi
i'm trying to use three external interrupts...
in this code the interrupts are working fine.. (I tested it with LED)
But i Cant Read Or Update the mic_num in this code
#define LED PORTD.F0
unsigned int mic_num = 0;
void interrupt()
if(INTCON.F1 == 1)
      mic_num = 1;
else if(INTCON3.F0 == 1)
      mic_num = 2;
else if(INTCON3.F1 == 1)
      mic_num = 3;
void main()
TRISD = 0x00;                      // for Display, LED, Relay
TRISC = 0x00;
TRISB = 0xFF;
LED =1;
delay_ms(1000);
LED =0;
PORTC = 0;
INTCON = 0b10010000;
INTCON2 = 0b01110000;
INTCON3 = 0b00011000;
RCON.IPEN = 0;
while(1)
      if(mic_num > 0) // this Part is not working
             LED = 1;
Hewitson
You are never resetting mic_num back to 0 so once an interrupt has occurred, mic_num will always be more than 1 and the LED will always be on.
r_guna_sekar
Newbie level 6
Chennai
please somebody give me a suggestion ....
i want to use three external interrupts....
PIC18F4520
qwertyuiop415263
Full Member level 4
Pakistan
what compiler you are using? where is interupt vector in your code?
also
you need to use the pull up resistor or pull down resistor(depends whether you assign portb=1 or portb=0 ) with interupt pins. also u didnt assign any value to portb interupt pins. you should write something like this.
TRISC = 0x00;
TRISB = 0xFF;
PORTB=0x00;
PORTD=0x00;
LED =1;
delay_ms(1000);
LED =0;
r_guna_sekar
Newbie level 6
Chennai
i'm using MikroC compiler.....
my all three interrupts are working (i tested it with LED)......
if(INTCON.INT0IF == 1)
LED = 1;
i'm using pull down resistor and i configured rising edge interrupt...
my issue is i cant update the mic_num while interrupt occurs...
Tahmid
Advanced Member level 5
Silicon Valley, California, USA (from Dhaka, Bangl
This is the fixed code:
void interrupt()
if(INTCON.F1 == 1)
      mic_num = 1;
      INTCON.F1 = 0;
      INTCON3.F0 = 0;
      mic_num = 2;
      INTCON3.F1 = 0;
      mic_num = 3;
void main()
TRISC = 0x00;
TRISB = 0xFF;
LED =1;
delay_ms(1000);
LED =0;
ADCON1 = 7;                          //Disable ADC
CMCON = 7;                           //Disable comparator
PORTC = 0;
RCON.IPEN = 0;
while(1)
             LED = 1;
2 problems:
1) Most importantly, the INT0, INT1 and INT2 pins are also multiplexed to ADC inputs. So, you have to first select them as digital pins by disabling the ADC and comparator.
2) You did not clear the flags. However, your problem was created due to what I've explained in point 1.
Hope this helps.
Tahmid.
