External interrupt and timer0 and timer1 using same time
cllunlu
Member level 4
Hi Everyone,
I have Project that two UHF antenna (they send wiegand data to microcontroller via RB4-RB7 IOC)
I have already read wiegand data from antenna succesfully.
Now I have to do when data is received and if readed tag is known, relay will be on for 2 second and after that will be off, and microcontroller wont be any process for before readed tag in 10 second. if readed tag is not known microcontroller wont do any process.
I write code but have some mistakes. Anyone help?
I am using pic18f24k50 and 12 Mhz external crystal.
I couldnt Show some functions to readability.
void start_timer1()
    timer1=0;
    TMR0IE_bit=1;
void interrupt(void)
     if(IOCIF_bit)   // RB4-RB7 interrupt
          IOCIE_bit = 0;
          IOCIF_bit = 0;
          if(!RB4_bit)    // Data is received from RB4
                wiegand[wCounter]='0';
                wCounter++;
                while(RB4_bit==0);
          else if(!RB5_bit)  // Data is received from RB5
                wiegand[wCounter]='1';
                wCounter++;
                while(RB5_bit==0);
          if(wCounter==26)
               finish=1;
          else
              IOCIE_bit = 1;
     if (TMR0IF_bit)
          TMR0IF_bit = 0;  // timer calculation from mikroElektronika software and it is true.
          TMR0H = 0x48;    // microcontroller is pic18f24k50, external crystal 12Mhz, 1 second timer interrupt
          TMR0L = 0xE5;
          timer1++;
unsigned short control_last_tag()
    unsigned short result=0;
    if(finish==1)
       if((receivedTag[0]==lastTag1[0]) && (receivedTag[1]== lastTag1[1]) && (receivedTag[2]==lastTag1[2]))
           if(timer1==0)
               result=1;
       else
           result=1;
    else if(finish==2)
        if((receivedTag[0]==lastTag2[0]) && (receivedTag[1]== lastTag2[1]) && (receivedTag[2]==lastTag2[2]))
             if(timer2==0)
                result=1;
        else
             result=1;
    return result;
void isRec_tag()
    unsigned short isRec=0;
    unsigned int currentAddr=startAddr;
    while(currentAddr<=finishAddr)         // control from start adress to finish address in eeprom, tag data is find?
             currentAddr++;
             if(EEPROM_Read(currentAddr)==receivedTag[0])
                 currentAddr++;
                 if(EEPROM_Read(currentAddr)==receivedTag[1])
                      currentAddr++;
                      if(EEPROM_Read(currentAddr)==receivedTag[2])   // Tag data is find.
                          if(control_last_tag()==1)        // Control last readed tag. Microcontroller wont any process, if readed tag is read in 10 second again.
                              if(finish==1)
                                   RELAY1=ON;
                                   start_timer1();
                              if(finish==2)
                                   RELAY2=ON;
                                   start_timer2();
                              write_last_tag();   // Update last readed tag
                      else
                           currentAddr+=1;
                 else
                     currentAddr+=2;
             else
                  currentAddr+=3;
void main()
    init();
    while(1)
           LED0 = ~LED0;
           Delay_ms(500);
           if(finish>0) // if all of tag data is received. If finish is 1, antenna-1 send data
           {                                            // If finish is 2, antenna-2 send data
               wCounter=0;
               calc_tag_data();   // Calculate received wiegand data to tag id
               isRec_tag();       // Control that readed tag is known?
               finish=0;
               IOCIE_bit = 1;     // IOC interrupt is on;
          if(timer1==2)        // if timer is value 2 second
             RELAY1=OFF;
          if(timer1==10)       // if timer is value 10 second
               timer1=0;
               TMR0IE_bit=0;
void init()
    /******* IOC RB4-RB7 interrupt ***************/
    IOCIE_bit = 1;
    PEIE_bit = 1;
    GIE_bit = 1;
    IOCB4_bit = 1;
    IOCB5_bit = 1;
    IOCIF_bit = 0;
    /************* TIMER1 ************************/
    T0CON         = 0x85;
    TMR0H         = 0x48;
    TMR0L         = 0xE5;
Try this
if((memcmp(receivedTag, lastTag, x) == 0)) //turn ON relay for 2 seconds
x is no. of elements receivedTag.
required changes into interrupt :
if(IOCIF_bit) to if(IOCIF_bit && IOCIE_bit)
and
if (TMR0IF_bit) to if (TMR0IF_bit && TMR0IE_bit)
I want to do that when microcontroller receive tag data, if tag data is defined before, relay will be on for 2 seconds after that microcontroller wont do any process for same tag.
So I set timer0 and when tag data is defined before, relay will be 2 seconds, but timer is 10 seconds, how can I stop timer.
To stop timer you have to use
TMR0ON_bit = 0;
