Extended C-Band PLL LNB
hishamuddinjohari
Malaysia
Hi All,
Anyone can help me to recognize LNA stage 1 to 3. I try to repair the CalAmp Extended C-Band PLL LNB. The problem is the the receiver received -45dBm and the BER 0.2. So I suspect the first stage LNA through stage 3 LNA. I've replaced the Bias IC ZNBG400 but no improvement on the reading.
Anyone can suggest the suitable components suitable to replace?
The pictures shows the 1st and 2nd stage LNA (I guess).
LNA stage 1 codes C. LNA stage 2 and 3 marked A9 (SOT343)
Thank you in advance.
You can replace with ATF54143, and you must design the input match circuit for ATF54143, otherwise that's vain.
I guess, that C=NE3512S02 and A9=MGF4931AM (A), Jan 2009 (9)
To vfone. C-Band PLL LNB with $10 Where is it!?
