Aug 10, 2017 #1 L laperla Full Member level 4 Joined Oct 17, 2009 Messages 191 Helped 2 Reputation 4 Reaction score 3 Trophy points 1,298 Activity points 2,364 I want to transfer PCB from ADS to Altium For exporting from ADS I use DXF/DWG format but when I import it to Altuim, the pcb will be same as picture how can I correct it?
Aug 10, 2017 #2 V volker@muehlhaus Advanced Member level 6 Joined Apr 11, 2014 Messages 3,188 Helped 1,071 Reputation 2,146 Reaction score 1,138 Trophy points 1,393 Activity points 20,252 For export to PCB systems, better use Gerber format. With DXF, so you might get the outline only, because zero width polygons are not interpreted as filled.
Aug 12, 2017 #3 L laperla Full Member level 4 Joined Oct 17, 2009 Messages 191 Helped 2 Reputation 4 Reaction score 3 Trophy points 1,298 Activity points 2,364 Thanks for replying In some papers, around passive filters are used polygon vias. How can I add them to thr pcb of Altium?
Aug 13, 2017 #4 V volker@muehlhaus Advanced Member level 6 Joined Apr 11, 2014 Messages 3,188 Helped 1,071 Reputation 2,146 Reaction score 1,138 Trophy points 1,393 Activity points 20,252 laperla said: In some papers, around passive filters are used polygon vias. Click to expand... I am not an Altium user, but try searching for "via fence". https://techdocs.altium.com/display/ADOH/Via+Shielding#
