Explanation of the shrink factor
mujju433
Full Member level 3
Full Member level 3
Can anyone explain me about shrink factor??
SHRINK FACTOR
There are some (old) technologies, for instance a 1um technology, that are simply scaled down. So a shrink factor is applied to them, but the PDK is not changed. So, you do your design, the models have been adapted, so on silicon it will work the same as you see on screen, you do the layout and when you submit it to fabrication, a certain shrink factor is applied to it all.
To you, as designer, it should be transparent.
    mujju433
SHRINK FACTOR
whats this PDK and wt kind of models are these??
SHRINK FACTOR
PDK means Process Design Kit. It is the whole package with the technology information: models, design rules, etc
Models are the electrical models of every component. The ones that you use to simulate
    mujju433
SHRINK FACTOR
Can u plz explain me more clearly
i am unable to understand clearly
Re: SHRINK FACTOR
shrink factor is a nominal factor which indicates the shrinkage of the chip after it is fabricated. if the shrinkage factor is 85% then when it is fabricated 15% of it's area is reduced.
SHRINK FACTOR
So in my design that is DTMF chip which i am doing in SOC encounter..... the shrink factor is 1 that means how much is the %??
Re: SHRINK FACTOR
hmmm... that's the first time i encountered such. i guess there's no shrinkage at all.
SHRINK FACTOR
Mr forkschgrad wt ur saying is right but wt i am saying is.....is there any difference between factor and %
We are not talking about the percentage dear we are asking about wt is shrink factor and how does it determined...On what basis do we have to give that shrink factor?
its just a factor not % remember and now answer..............
Can anyone answe my question
