boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
I have implemented this circuit in multisim 11 and have been exploring it but I am not certain whether or not this software accurately simulates the behaviour of the real circuit.
In multisim of you use a virtual oscilloscope to probe the circuit at the 555 out put pin then you get the expected square wave with a low of 0V and a high of about 9V.
However if you probe just after the 2.2kR resistor you get a reduced amplitude square wave with the low raised to about 5V or so.
I do not understand this. If you simply connect a resistor to a source and probe this simple circuit after the resistor then you find that the horizontal line lowers from 12V to roughly 5V or what ever.
So I would expect that in the above circuit that the resistor would lower the voltage peaks from the 555 to less than 9V. But, according to multisim, it actually raises the low voltage.
Why does this occur?
Or is that multisim is not quite accurately simulating the behaviour of the circuit or I am not using its virtual oscilloscope correctly?
I am intending to implement a very simple voltage divider interface to a pc sound card line in socket so that I can roughly examine the behaviour of the real cicrcuit and compare it to multisim.
Also, the designer of this circuit have specifically chosen to invert the signal from the 555 via the BC327 PNP.
Does anyone know why it is advantageous to do this? Why not a NPN transitor?
