khubu
- Joined
- Aug 9, 2013
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 55
Please help me to find a excitation to Cpw-fed.
I tried but their is an problem like..
"[info] Fast sweep setup, process hf3d: '1' conductors touch lumped port '1', typically a lumped port contains 2 conductors. Please verify conducting boundaries and objects are correctly assigned and touch the port. If a Radiation boundary touches the port and it is desired for use during the port solution, select 'Use Radiation Boundary on Ports' under the Advanced tab in the Solution Setup. (3:20:29 AM Aug 10, 2013)
[info] Normal completion of simulation on server: Local Machine. (3:20:30 AM Aug 10, 2013)"
And i want to complete it ASAP..! please provide a solution. I have design a Slot square patch antenna with CPW-fed with a lumped port.
