neazoi
Advanced Member level 6
This is a nice simple dual purpose HV PSU **broken link removed** I have found.
What is your opinion about the circuit, is seems very straight forward.
I also consider the next modifications and I would like your oppinion about these:
1. Adding a 220uF capacitor at the base of Q1 for less ripple.
2. Adding a 1000uF shunt capacitor at the collector of Q1 to GND. This would be good on BT ON but I do not know what will be the behaviour of this capacitor on THT ON, because the capacitor will effectively shunted between the flyback transformer pin 2 and the GND.
3. It is not clear to me what R2 does. It should limit the input voltage on the 78L12 so that it does not exceed 30V but how is it accomplished with a just a current limiting resistor?
