Register Log in
Ethernet PHY - SGMII Auto-negotiation
maestor
Full Member level 3
España
sgmii phy
Hi guys,
Not sure if this the right group for posting this...but there it goes.
I've got a board with GbE SFP transceivers from @g!lent (I've tried F!nisar ones as well). Part number H=B=C=R-5=7=1=0=R(remove the '='). It's a GbE PHY (it uses the M@rvell 8E1111 as most of them). On the serial end I've got an SGMII MAC.
I connect the SFP with a CAT-5 cable to a GbE card on my PC and lights come on...link/full duplex...I read the SFP PHY registers using the I2C interface and all makes sense (Autonegotiation-AN finished, 1000BASE-T detected...), happy camper.
Then I try the 10/100 BASE-T then. I connect the SFP to a 10/100 hub (it's got Autonegotiation capability, checked that) and no lights come on. I read the status registers and reports error during AN. I have tried with and without SGMII enabled and the same. Disabling the back-end MAC and enabling it and nothing... :?
Has anybody worked with the 8E1111 PHY in 10/100 before?
Any help much appreciated, I'm stuck.
Regards,
-maestor
au_michael
Newbie level 6
sgmii auto negotiation
From what you say I believe that you have problem on the SFP RJ45 module. Firstly please check whether the PHY is in AUTONEG. If it is so, please force the PHY into 100M and full duplex, and then see whether it could link. If all fail, I wish you could upload you sch in order that all the expert could help you.
Best Regards
maestor
Full Member level 3
España
8e1111
Hi au_michael,
Finally an answer, thanks a lot.
About the schematics, I think they are all right, no issues there. It works for Gigabit SGMII so I was expecting it to work @ 10/100 because, just because it's SGMII.
I didn't mention it before but the back end is an MGT in a 2vp50 with a MAC (HDL I wrote :) ) it works just fine @ 1Gbps
About the autonegotiation...
1) the PHY is definitely in AUTONEG
2) I have tried to force 100 full duplex and not even like that.
I am working on the back end FIfos of the MAC @ 1Gbps so not too bothered about 10/100 but I'd like to get it working. I might have to contact the technical guys for @g!lent.
Have you worked with these PHYs before?
-maestor
au_michael
Newbie level 6
sfp phy
I do use 88E1111 in my some switch. But I did not use the SGMII mode and SFP RJ45. I am sorry to answer your question right now. However, your problem is very strange and interesting. So I will try to find the reseaon how could the serial data be transformed to parallel data.
maestor
Full Member level 3
España
sgmii sfp
Thanks again,
The problem with the SFPs is that the embedded 88E1111 is not fully functional. It just been hard configured to work in SGMII mode for 10/100 such that repeats the data in the serial link 10 or 100 times depending of the link speed.
When I find the way around this I'll let u know...no rush though. It's not critical in our app.
-maestor
se06745
Junior Member level 3
sgmii autonegotiation
I'm working with Agilent's SFP and is true, you need a SGMII compatible MAC to work in 10/100 Modes becuase SFP repeat each byte 100/10 times to obtain 1Gbit data flow. The MAC must understand that.
King regards!
angelote
Spain
sfp sgmii
Do you use the same cable for both connections?
To connect directly to a PC you need a crossed cable (like null modem). To connect to a hub you should use a direct cable. Have you checked it?
KlausM
Newbie level 1
sgmii autoneg
We have a similar problem with an optical 100FX SFP from Cisco: GLC-GE-100FX=.
It also contains an internal PHY, but in this case it is a Broadcom BCM5461S.
The problem is that it is not possible for us to get a detailed data sheet on neither the SPF nor the PHY.
Does anyone know how to get such SFP modules to work, we can't even get it to emit light!
Best regards
naga_prasu
Newbie level 1
sgmii
hai,
u can do one morething.
just disable auto-negatiation & just force 100Mbps and Full duplex.
sometimes PHY to PHY interface creates this problem.
Thanks & Regards
shooti
Newbie level 3
sgmii mode
Dear guys
Does any one have 88e1111 data sheet?
I mean some thing more than the available one (2 pages document)
Thanks in advance
SiTiCompany
Newbie level 2
Re: sgmii sfp
How do you configure SFP to work in SGMII? Via I2C? Can anyone help me to find register map for D+G+S-7+1+2 (remove +) SFP module? I can't work with it on 10/100. Only 1000. Sorry for offtopic.
SiTiCompany
Newbie level 2
Re: sgmii sfp
Problem is solved. This modules in fact is a Finisar FCLF-8521-3 modules, and configuration of this module is in FAQ AN-2036
This module based on 88e1111 and suppot 100Base-Tx with autonegotiation (my module support).
