[AVR] Ethernet connection failure (arduino)
archusvijay1
Member level 3
EThernet connection failure(arduino)
Hello,
I am trying to implement a device which read voltage and current and send the signal to a server.I completed this task using arduino uno and ENC28j60 Ethernet module with the help of UIPEthernet library. I am getting the signal in the server.but some time it fails .It maybe after running half a day,or after one day.also i get continuous signal for 2 days also.after that it will hang or not sending the data to the server. What might be the problem?.please help .
i here by attach the program .
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
void setup(){
 Serial.begin(9600);
  //Serial.println("Starting");
  SPI.begin();
 // watchdogSetup();
  pinMode(Contd,OUTPUT);
  pinMode(NotContd,OUTPUT);
  digitalWrite(Contd,HIGH);
  digitalWrite(NotContd,HIGH);
  delay(2000);
  digitalWrite(Contd,LOW);
  digitalWrite(NotContd,LOW);
  start_ethernet();
void loop() {
  //wdt_reset();
      reset_millis = millis();
      // put your main code here, to run repeatedly:
  if(reset_millis >= reset_period){
        Resetuno();
    dc_volt = 0;
    dc_volt   = analogRead(A5);//*5)/1024);
    dc_volt = dc_volt*0.0363;
    eb_volt   = Measure_Vrms(1,800,0.8759,10);//1.1    4.04///
    inv_curr  = Measure_Irms(4,800,0.039,10); //0.0017
    client.connect(server, 80);
    delay(1000);
  if (client.connected()){//(server, 80)) {
    Serial.println("-> Connected");
    failed_data = 0;
    client.print( "GET /index.php/add/add_data?");
    client.print("dc_volt=");
    client.print(dc_volt);
    client.print("&");
    client.print("eb_volt=");
    client.print(eb_volt);
    client.print("&");
    client.print("inv_volt=");
    client.print(inv_volt);
    client.print("&");
    client.print("inv_curr=");
    client.print(inv_curr);
    client.print("&");
    client.println( " HTTP/1.1");
    client.print( "Host: " );
    client.println(server);
    client.println( "Connection: close");//keep-alive" );// close
    client.println();
    client.println();
    client.stop();
   delay(interval);
Re: EThernet connection failure(arduino)
there are a lot of reasons.
1st thing i would check is if my ethernet is ok.
so i would try to send ping to connected pc, and run it constantly
for a long time to check if the ping doesn't stop.
(there might be some clocking issues in phy/switch for example, or bad cables or terminations).
My Ethernet connection is OK. I replace the cable also.
during the debugging time i can notify that it is not come out side from the client.connected() function.
so it is probebly a software problem with the uipethernet.
so you might check if you got the latest vesion
of this library.
of this library.
yes . i am using the latest version.This problem exist some times only.
I think the problem comes from the client.print() or client.stop() function. After connecting the server (ie.client.connected() is true) the net disconnected the system hang.am i right?.
can i use watch dog timer to overcome this problem or any other method to resolve this problem?
