Register Log in
Estimating Frequency in PLL from estimated phase
chessmath2009
Newbie level 6
Hi
Assume I have a digital PLL that outputs phase estimate of the reference signal, however I am wondering can I estimate the frequency of reference signal according to the given phase estimate? I know frequency is derivative of phase respect to time but dont we need a operating or center frequency of VCO(NCO). Can anyone guide me to find an algorithm to estimate the reference frequency ?:
KlausST
Super Moderator
Staff member
F_out = f_in * n(m) * n(d)
Where n(m) is the integer multiplying factor and n(d) is the integer divider
The other way round: F_in = f_out * n(d) / n(m)
It is a fixed relationship given by n(m) and n(d)
Klaus
chessmath2009
Newbie level 6
I am sorry can you elaborate about this things?
I do not have any divider by N in my PLL and I would like to estimate the frequency of the signal based on estimated phase. I have only phase detector, loop filter and VCO (NCO).
Warpspeed
Advanced Member level 5
Melbourne, Australia
If the two frequencies are far apart, phase information will be changing so fast, it may be unable to find lock.
The reason being it tries to pull the frequency one way over half a cycle, then in the opposite direction during the following half cycle.
The solution is a combined phase/frequency detector.
Here is a good read on phase detectors, scroll down to page 18 for phase/frequency detector.
http://www.artechhouse.com/uploads/public/documents/chapters/goldman_154_ch05.pdf
KlausST
Super Moderator
Staff member
If you don't have a divider, the the output frequency will be the same as the input frequency.
But the output of the loop filter is the input to the VCO. So yes, the voltage relates to the output frequency.
But it may have a lot of errors: offset, gain, unlinearity...
Maybe you could show us your circuit, so we can detailed talk about it.
Klaus
zorro
Argentina
The voltage at the input of the VCO (or the number at the input of the NCO), i.e. the value at the output of the filter loop, gives the indication of the frequency at which the oscilator is running.
If the PLL is locked, that is the frequency of the signal.
Z
Toggle Sidebar
