iam jayanthi
i need a help from you.in most of the papers(on PIFA) they are not mentioning the length of the short that is in X axis.they are mentioning only the height and the width of the short.by using which option we have to draw the shorting post.
what i followed to draw the shorting post is,first i will select the portion actually where i need the short in radiating plate.then i go to basic parameters and i change the metal width as height of the short is needed.whether this method is correct or not?
jayanthi
Do you mean the shorting pin or strip at the end of a PIFA? It is confusing to say x because I am not sure how to place the PIFA in the coordinate. Maybe you can give me some simple drawing on it. Regards.
