Hello,
We have some offline, linear regulator based LED drivers which are dimmable with their PIC18F26K20. (we are using ICSP with Pickit3 to program it)
Some of the PCBs work, most don’t, and some work the first time they are powered up but never thereafter. By “non-working”, I mean they light up but don’t respond to DALI dimming commands sent to the PIC18F26K20.
We have had 1000 of the PCBs made and assembled, and then realised that we forgot to add a 10k pullup resistor from the MCLR pin to Vdd. (MCLR reset is disabled, so its an input pin).
We then had an external modification applied to the PCBs which involves wiring a 10k resistor from MCLR pin to Vdd, and a 10n capacitor from MCLR pin to Vss. I undid this modification on one of the few working boards and then found that stopped it working. –But when I re-did this modification the PCB still did not work.
I am assuming that we have violated the dreaded MCLR pin here… The MCLR pin has no ESD protection diodes due to its use in ICSP, and so am I right in saying that the MCLR pin is supersensitive to ESD, and dies very easily?
(To make matters worse our supply capacitor next to the micro is just a 4n7, 0402 capacitor. However, there are two 10u, 0805 ceramic capacitors about 8mm away from the PIC.)
Do you think we are wasting our time trying to modify these boards? Is the MCLR pin so ultra-sensitive to ESD that everywhere from the PCB assembly house to our factory it is going to get its MCLR pin killed because we forgot to add the 10k resistor from MCLR to Vdd?
PIC18F26K20 datasheet...
