drc rules tetramax
Hi everyone,
I am getting some errors while running Tmax during DRC:
How to overcome these errors..
DRC> set drc /home/student1/sk4xilinx/proj4/proj4stil.spf
run drc
Begin scan design rules checking...
Begin reading test protocol file /home/student1/sk4xilinx/proj4/proj4stil.spf...
Error: Line 10 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "a" is not a netlist pin). (V5-1)
Error: Line 11 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "b" is not a netlist pin). (V5-2)
Error: Line 12 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "c" is not a netlist pin). (V5-3)
Error: Line 13 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "clk" is not a netlist pin). (V5-4)
Error: Line 14 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "d" is not a netlist pin). (V5-5)
Error: Line 15 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "e" is not a netlist pin). (V5-6)
Error: Line 16 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "f" is not a netlist pin). (V5-7)
Error: Line 17 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "sen" is not a netlist pin). (V5-8)
Error: Line 18 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "fout" is not a netlist pin). (V5-9)
Error: Line 19 (/home/student1/sk4xilinx/proj4/proj4stil.spf), unresolved reference (Signal "test_si" is not a netlist pin -- Too many errors; parsing terminated). (V5-10)
End parsing STIL file /home/student1/sk4xilinx/proj4/proj4stil.spf with 10 errors.
Error: Design rules checking failed: cannot exit DRC command mode. (M100)
