errors when using PrimeTime-PX
cashen224
Hi
I am a new comer in ASIC design. I am now trying to use PrimeTime-PX for (post-synthesis) timing analysis and power estimation.
I saw a lot of errors like following error message while executing PT:
"Error: No net timing arc from pin 'U555/Q' to pin 'path_metric_compute/add_87/U1_14/B'. (PTE-014) ".
I guess the library or import files I sent to PT were wrong since it looks like all the paths were wrong. I sent nestlist, .sdf file, .sdc file, and .spef file from DC to the PT and I am using Synopsys education 90nm library (SAED90nm Library).
Could you please advise me what could be the problem causing this? I really appreciate any help.
wsong0210
Member level 3
Manchester, UK
Seems like your .v file does not match with your .sdf file. Check which one is not updated to the new version.
cashen224
Thanks for all the helps.
I just realized that there is a version mismatch between DC and PT. I used newer version of DC than PT.
wsong0210
Member level 3
Manchester, UK
Personally I dont think the version mismatch is a problem unless the version is mismatched too much (like more than 3 major version difference)
michealwolf
Junior Member level 1
How do you back annotate the design, SPEF or SDF?
It probablly because of mismatches of SPEF/SDF vs NETLIST.
Or you used some wrong commands that constrains the non-exists timing arcs.
