ksj116
Newbie level 6
calibre runset file
Recently there are always sth wrong with the calibre when loading my runset file. I saved all calibre pex GUI envirment parameters settings as the named 65nm_pex AND i can run the XXX block PARASITIC EXT successfully, but i failed when i run the next block pex extraction. the errors statements are as the following ;“ Format error encountered in runset file "XXX/65nm_pex". The file is probably not a runset file.”
But i can successfully run the previous block by loading the file. i cannot resolve it.
your help is very appreciated.
