Errors when importing a file from Orcad Schematic to PCB Editor
HANUMAGOUDA
Member level 1
BANGALORE
PROBLEM IN ALLEGRO
Hi all,
i am facing the problem while importing the file from orcad schematic to the pcb editor . give me the hints how to solve this type of problems.
Packager files not found
#2 ERROR(102) Run stopped because errors were detected
netrev run on Jul 10 13:09:50 2010
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
2 errors detected
No oversight detected
No warning detected
cpu time 0:00:23
elapsed time 0:00:01
I am waiting for you reply .
Thanking you,
Hanumagouda Patil
PROBLEM IN ALLEGRO
try the followings
1. save DSN and BRD file in same path not in Desktop(this is not necessary if you can map them correctly..still try)
2. map the padpath,pasmpath in allegro (make sure all reqired dra files ,pad files and psm files are avilable in this path)
3.generate netlist from captureCIS (can put a . if you want to store the netlist in same folder)
4. import the netlist to Allegro
