Error while loading Calibre runset
crystal
Full Member level 1
error inp7
I was using the LVS header file to run parasitic extraction but I am facing this error again and again:
"Error INP7 on line 256 of .../calibre_lvs.rul - incomplete keyword specification - pex"
I am a newbie in Calibre and upon checking, I can't find "PEX" being define in the runset. Is something missing? Or I am missing some link here?
Can someone tell me where is this "PEX" normally define?
Your help is much appreciated.
incomplete keyword specification:
Is it a license issue?
or something else?
incomplete keyword specification: pex
inp7 calibre
Can any one reply the Error?
this is maybe caused by you calibre version.In the latest version of calibre pex,many keyword in the old version are not support.You can find what has changed in the help doc.
error inp7- incomplete keyword specification:pex
I had the same error - "Error INP7 on line 256 of .../calibre_lvs.rul - incomplete keyword specification - pex"
I looked up the rule file and the line was like this - (of cause line number is different- mine was 543 or something)
"PEX XCALIBRATE VERSION CLASSIC v2007.3_36.24"
Then I realized current Calibre version was different, so I commented out that line with "//"
Right now, no more error and it seems fine. I think my version difference wasn't huge, but if it's very big difference, you should update your Calibre.
I hope it helps you.
