Error when reading AT89s52 ISP : device signature mismatch
laoya82
Newbie level 5
AT89s52 ISP
I'd constructed the AS*M Kh*n ISP circuitry. When i try to read the µC, the program show a msg as "Device signature mismatch". Even when i try to press the signature button, msg of "no responce from µC" is shown? Do anyone know how to solve this?
Re: AT89s52 ISP
This may be due to ECP/EPP mode of LPT port. Try changing the mode to normal and then retry.
Which OS are you using?
Re: AT89s52 ISP
I'm using ECP mode of LPT1 under window XP. Wat procedure I should take to chg the ECP to normal mode? Is the 4Mhz crystal in the schematic has to be connected to the GND? ....................Need ur help!
Re: AT89s52 ISP
For AS*M Kh*n ISP circuitry. Is there any configuration needed to be done before using its program. It keep showing "Device signature mismatch"and "no responce from µC". Can anyone help me on this? Please give ur opinion.
Re: AT89s52 ISP
You can change the mode through BIOS settings during boot-up.
Since you are using WIN-XP, problem may be the OS also. Parallel port access in XP is different than Win-95-98. Check whether ISP software supports XP or not.
AT89s52 ISP
i tried to program 89s8252, bu it didnt suceed,
maybe xp caused the problem
