i have mounted the circuit of an ICD of microchip and program a 16F877A with the bootloader of CCS. It programs the target, but in the debugger mode, it returns an error:
"Could not star target: the target was not halted after reset. Check the target oscillator and MCLR"
The target have a 20Mhz cristal.
I don't know what's the problem. It program, but not debug....
you must connect only 47k resistor from MCLR pin to VCC, then ICD-XX will work as debuger. See CCS documentation how to using
ICD, www.ccsinfo.com
Regards: Svetoslav Pirev
