module neso_ddr3(
input clk_in,
// DDR3 Physical Interface Signals
//Inouts
inout [15:0] ddr3_dq,
inout [1:0] ddr3_dqs_n,
inout [1:0] ddr3_dqs_p,
// Outputs
output [13:0] ddr3_addr,
output [2:0] ddr3_ba,
output ddr3_ras_n,
output ddr3_cas_n,
output ddr3_we_n,
output ddr3_reset_n,
output [0:0] ddr3_ck_p,
output [0:0] ddr3_ck_n,
output [0:0] ddr3_cke,
output [0:0] ddr3_cs_n,
output [1:0] ddr3_dm,
output [0:0] ddr3_odt,
// LEDs to signal pass/fail
output reg led_pass,
output reg led_fail,
output wire led_calib
wire calib_done;
reg [27:0] app_addr = 0;
reg [2:0] app_cmd = 0;
reg app_en;
wire app_rdy;
reg [127:0] app_wdf_data;
wire app_wdf_end = 1;
reg app_wdf_wren;
wire app_wdf_rdy;
wire [127:0]app_rd_data;
wire [15:0] app_wdf_mask = 0;
wire app_rd_data_end;
wire app_rd_data_valid;
wire app_sr_req = 0;
wire app_ref_req = 0;
wire app_zq_req = 0;
wire app_sr_active;
wire app_ref_ack;
wire app_zq_ack;
wire ui_clk;
wire ui_clk_sync_rst;
wire sys_clk_i;
reg [127:0] data_to_write = {32'hcafebabe, 32'h12345678,
32'hAA55AA55, 32'h55AA55AA};
reg [127:0] data_read_from_memory = 128'd0;
// Power-on-reset generator circuit.
// Asserts resetn for 1023 cycles, then deasserts
// `resetn` is Active low reset
reg [9:0] por_counter = 1023;
always @ (posedge clk_in) begin
if (por_counter) begin
por_counter <= por_counter - 1 ;
end
end
wire resetn = (por_counter == 0);
// Clock Wizard
// DDR3 core requires 200MHz input clock
// We generate this clock using Xilinx Clocking Wizard IP Core
clk_wiz_0 inst
.clk_in1(clk_in),
.clk_out1(sys_clk_i)
// Instatiation of MIG core named `mem`
mem mem (
// DDR3 Physical interface ports
.ddr3_addr (ddr3_addr),
.ddr3_ba (ddr3_ba),
.ddr3_cas_n (ddr3_cas_n),
.ddr3_ck_n (ddr3_ck_n),
.ddr3_ck_p (ddr3_ck_p),
.ddr3_cke (ddr3_cke),
.ddr3_ras_n (ddr3_ras_n),
.ddr3_reset_n(ddr3_reset_n),
.ddr3_we_n (ddr3_we_n),
.ddr3_dq (ddr3_dq),
.ddr3_dqs_n (ddr3_dqs_n),
.ddr3_dqs_p (ddr3_dqs_p),
.ddr3_cs_n (ddr3_cs_n),
.ddr3_dm (ddr3_dm),
.ddr3_odt (ddr3_odt),
.init_calib_complete (calib_done),
// User interface ports
.app_addr (app_addr),
.app_cmd (app_cmd),
.app_en (app_en),
.app_wdf_data(app_wdf_data),
.app_wdf_end (app_wdf_end),
.app_wdf_wren(app_wdf_wren),
.app_rd_data (app_rd_data),
.app_rd_data_end (app_rd_data_end),
.app_rd_data_valid (app_rd_data_valid),
.app_rdy (app_rdy),
.app_wdf_rdy (app_wdf_rdy),
.app_sr_req (app_sr_req),
.app_ref_req (app_ref_req),
.app_zq_req (app_zq_req),
.app_sr_active(app_sr_active),
.app_ref_ack (app_ref_ack),
.app_zq_ack (app_zq_ack),
.ui_clk (ui_clk),
.ui_clk_sync_rst (ui_clk_sync_rst),
.app_wdf_mask(app_wdf_mask),
// Clock and Reset input ports
.sys_clk_i (sys_clk_i),
.sys_rst (resetn)
localparam IDLE = 3'd0;
localparam WRITE = 3'd1;
localparam WRITE_DONE = 3'd2;
localparam READ = 3'd3;
localparam READ_DONE = 3'd4;
localparam PARK = 3'd5;
reg [2:0] state = IDLE;
localparam CMD_WRITE = 3'b000;
localparam CMD_READ = 3'b001;
assign led_calib = calib_done;
always @ (posedge ui_clk) begin
if (ui_clk_sync_rst) begin
state <= IDLE;
app_en <= 0;
app_wdf_wren <= 0;
end else begin
case (state)
IDLE: begin
if (calib_done) begin
state <= WRITE;
end
end
WRITE: begin
if (app_rdy & app_wdf_rdy) begin
state <= WRITE_DONE;
app_en <= 1;
app_wdf_wren <= 1;
app_addr <= 0;
app_cmd <= CMD_WRITE;
app_wdf_data <= data_to_write;
end
end
WRITE_DONE: begin
if (app_rdy & app_en) begin
app_en <= 0;
end
if (app_wdf_rdy & app_wdf_wren) begin
app_wdf_wren <= 0;
end
if (~app_en & ~app_wdf_wren) begin
state <= READ;
end
end
READ: begin
if (app_rdy) begin
app_en <= 1;
app_addr <= 0;
app_cmd <= CMD_READ;
state <= READ_DONE;
end
end
READ_DONE: begin
app_en <= 0;
end
if (app_rd_data_valid) begin
data_read_from_memory <= app_rd_data;
state <= PARK;
end
end
PARK: begin
if (data_to_write == data_read_from_memory) begin
led_pass <= 1;
end else if (data_to_write != data_read_from_memory) begin
led_fail <= 1;
end
end
default: state <= IDLE;
endcase
end
end
endmodule // top
I just try to compile, and it gave me ERROR.
Maybe you told Vivado that it's a VHDL file?
C:\test\edaboard>vlog neso_ddr3.v
Start time: 07:42:41 on Mar 26,2020
vlog neso_ddr3.v
Model Technology ModelSim DE-64 vlog 10.5b Compiler 2016.05 May 21 2016
-- Compiling module neso_ddr3
Top level modules:
neso_ddr3
End time: 07:42:41 on Mar 26,2020, Elapsed time: 0:00:00
Errors: 0, Warnings: 0
C:\tes\edaboard>vcom neso_ddr3.v
Start time: 07:42:56 on Mar 26,2020
vcom neso_ddr3.v
Model Technology ModelSim DE-64 vcom 10.5b Compiler 2016.05 May 21 2016
-- Loading package STANDARD
[COLOR="#FF0000"][B]** Error: neso_ddr3.v(1): near "module": syntax error[/B][/COLOR]
End time: 07:42:56 on Mar 26,2020, Elapsed time: 0:00:00
Errors: 1, Warnings: 0
reg [127:0] data_to_write = {32'h00AAAAAA, 32'hAAAAAAAA, 32'hAAAAAAAA, 31'hAAAAAAF} & {sw}; ?output [29:0] led,
input [3:0] sw
reg [127:0] data_to_write = {32'h00AAAAAA, 32'hAAAAAAAA, 32'hAAAAAAAA, 31'hAAAAAAF, 1'b0000};
reg [127:0] data_to_write = {32'h00AAAAAA, 32'hAAAAAAAA, 32'hAAAAAAAA, 31'hAAAAAAF, sw};
Possibly...
But the OP is using vivado 19. which makes default use of xsim compiler.
The OP was not specific about the compiler used.
[Synth 8-1002] sw is not a constant ["C:/Users/umt/Documents/cam_ddr_pipe/cam_ddr_pipe.srcs/sources_1/new/veri.v":64]
WRITE_DONE: begin
app_en <= 0;
end
app_wdf_wren <= 0;
end
state <= READ;
end
end
WHEN WRITE_DONE =>
if (app_rdy = '1') and (app_en ='1') then
app_en <= '0';
end if;
if (app_wdf_rdy = '1') and (app_wdf_wren = '1') then
app_wdf_wren <= '0';
end if;
if (not app_en = '1') and (not app_wdf_wren = '1') then
state <= READ;
end if;
WRITE_DONE: begin
app_en <= 0;
end
app_wdf_wren <= 0;
end
state <= READ;
end
end
WHEN WRITE_DONE =>
app_en <= '0';
end if;
end if;
state <= READ;
end if;
Code VHDL - [expand] 1 2 3 if (not app_en = '1') and (not app_wdf_wren = '1') then state <= READ; end if;
Code VHDL - [expand] 1 2 3 if (app_en = '0') and (app_wdf_wren = '0') then state <= READ; end if;
